View unanswered posts | View active topics It is currently January 21 2020, 1:45 PM
Reply to topic  [ 7 posts ]
 Rotary Engine News
Post Rotary Engine News
Well instead of having a new thread everytime, why not post it all in the same thread?
http://wardsauto.com/vehicles-amp-technology/mazda-design-breakthrough-may-give-rotary-new-life
Quote:
HIROSHIMA, Japan – The rotary is dead. Long live the rotary.
Despite plans to stop production of the RX-8 sports coupe in June and no commitment from management to replace it with another Wankel-powered car, Mazda may be on the verge of a major rotary breakthrough. Mitsuo Hitomi, general manager-powertrain development, says the auto maker soon will complete development of an all-new rotary engine that meets future fuel-economy and emissions standards. While Hitomi won’t confirm a completion date, his disclosure is evidence the rotary is alive and well at Mazda and that a new car powered by the engine could be on the way. “We think we’ve found a way to improve the rotary’s fuel economy to be truly equal to that of conventional piston engines and, if so, we believe we can reintroduce the rotary to the market,” he tells WardsAuto in an interview.
Hitomi declines to pinpoint when that might happen, but suggests the timeframe roughly would be equivalent to any other engine plugged into one of Mazda’s vehicle programs. Best guess is two years, once the application has been determined. Fuel economy and emissions were improved in the developmental engine “first, by changing the shape of the troichoid housing,” the Mazda executive says. “The rotary has many seals, and ‘sealability,’ particularly at the apex, or tip, of the rotor has been a longstanding problem” dating back to the mid-1960s and the Cosmo Sport, Mazda’s first rotary car. “Even with our current 1.3L Renesisrotary, gaps can develop between the apex seal and troichoid housing in light-load operation when imbalances in centrifugal force and gas pressure occur,” he says. Specifically, centrifugal force pushes the seal onto the housing surface. In low engine-rpm ranges, or under low-load conditions, gas pressure in the combustion chamber can cause the seal to lift off the surface, resulting in combustion gas leaking into the next chamber. By changing the shape of the troichoid housing, the seals remain flush to the housing, Hitomi says. “In addition to reducing emissions, better sealing improves fuel economy and overall performance.” A second engineering enhancement focuses on ignition. “I can’t specify how we plan to address this problem,” the Mazda engineer says, “but the rotary’s spark plug is in a recessed position (below the housing surface), compared to that of a piston engine. This causes ignitability problems and increases fuel consumption. We’ve found a way to make dramatic improvements,” he says. In June, AutoCar reported Mazda would introduce a laser-injection system to replace conventional spark plugs.
Hitomi counters popular perception that a rotary engine’s fuel economy is inherently poor. “In the past, Mazda engineers made a conscious decision to focus on the rotary’s weaker points – low torque, for instance,” he says. “This led to adopting a complicated and large variable-intake system, as an example. Moving forward, we plan to put greater emphasis on the rotary’s strong points – low vibration, compact size and high power output. And in this way, we can improve fuel economy.”
One result of that: Mazda will simplify the intake system, which in turn will reduce engine size. Hitomi believes the new engine eventually will be adopted for extended-range electric vehicles like the Chevrolet Volt. He doesn’t say so, but that could mean a future RX-8, RX-9 or even an RX-7 EREV. Mazda isn’t alone in looking at EREV applications for rotary engines, which are drawing interest from others, including engineering experts AVL, for their compact size and light weight.
The new Mazda engine will not necessarily be the 16-X prototype displayed at the 2007 Tokyo Motor Show, which reportedly was targeted at 1.6L in displacement and would generate 350 hp. Mazda’s Skyactiv fuel-efficiency technology could be applied to the new rotary, as well. “I think that whatever engine we introduce – conventional gasoline and diesel or rotary – the technology is applicable,” Hitomi says.
At a press briefing in December, Hirotaka Kanazawa, senior managing executive officer in charge of Mazda’s technical operations, openly discussed three Skyactiv engine series: the gasoline Skyactiv-G now on the market, diesel Skyactiv-D and rotary Skyactiv-R.
Since 1967, when Mazda introduced Cosmo Sport, the auto maker has sold nearly 2 million rotary vehicles. In the engine’s 1970s heyday, four out of five Mazdas sold in the U.S. were rotaries.
March 02 2012, 4:12 PM
Profile ICQ WWW
Post Re: Rotary Engine News
I really hope it works and we see a new rx-7 especially with flip up lights!
#5389 to join MX-3.com
April 10 2012, 7:10 PM
i dont think car manufactures are allowed to make flip up lights anymore but i do hope this comes through
April 23 2012, 6:04 PM
Profile YIM
Nothing that hasn't been said before, and an update to confirm is always good
http://www.autoblog.com/2012/04/18/mazd ... for-skyac/
Quote:
Apr 18th 2012 10:31AM
The minds at Car and Driver recently took a moment to speak with Robert Davis, senior vice president of Mazda U.S. operations, about the automaker's plans for the future. According to Davis, the rotary engine will continue to play a role in the company's products moving forward, with engineers applying the lessons learned through the SkyActiv program to the powerplant. That means the next-generation rotary will likely feature reduced internal friction and lightweight internals in a quest to reduce emissions and increase fuel economy. But the engine may find applications outside of its traditional role.
Not only is Mazda pursuing a rotary engine to power a vehicle, Davis admits Mazda is also investigating ways to use the design in tandem with an electric motor, with the pistonless engine responsible for charging an extended-range EV's batteries. Given the compact size and relatively low torque supplied by a rotary, this application would seem to hold promise. Of course, we've heard some of this before.
May 03 2012, 11:50 AM
Profile ICQ WWW
Booooo no hybrid crap just a straight up sexy sounding rotory
May 03 2012, 1:40 PM
what happened to there hydrogen rotary that was kinda cool :shrug:
but yeah this time the RX whatever needs to be a real sports car, just like the RX-7 was.
July 01 2012, 2:56 PM
Profile YIM
thats crazy cool news imagine if rotary is any better on gas
September 11 2015, 10:16 PM
