View unanswered posts | View active topics It is currently July 15 2020, 3:14 PM
Reply to topic  [ 5 posts ]
 94 mazda mx3 - 1.6L, 5speed - driver side axle problem
Post 94 mazda mx3 - 1.6L, 5speed - driver side axle problem
The driver side axle is "stuck" on the inside connection. My local mechanical spent a couple of hours trying to uninstall the axle to no avail. Any ideas?
June 06 2016, 8:42 AM
Post Re: 94 mazda mx3 - 1.6L, 5speed - driver side axle problem
Hi!
So, there's a spring clip that sits on the axle that holds it inside the transmission (part #1 in the manual link below). There are many methods that people say get these things out.
http://www.mx-3.com/manuals/showimg.php ... _M-028.gif
Here's a few thread from the forum on the issue. They should give you some ideas.
viewtopic.php?f=30&t=80098&hilit=circlip
viewtopic.php?f=30&t=77455&hilit=circlip
Wings on an MX3? What are you thinking?
92 RS BP05
93 GS KLZE
(Previously owned by 2Fazed and then mrMazda92)
May 08 2017, 10:10 AM
Profile YIM
There is an axle puller you can probably rent it. I used one and the axles just popped out.
May 08 2017, 9:19 PM
I used giant wheel/tire iron and wedged it between axle and transmission and pulled on it, axle popped right out.
May 16 2017, 9:51 AM
Profile ICQ YIM WWW
I love it when you talk dirty ;)
May 19 2017, 12:12 AM
