View unanswered posts | View active topics It is currently July 05 2020, 5:43 AM
Reply to topic  [ 2 posts ]
 radiator question
Post radiator question
so im nearing the completion of my swap. the lines that go from the radiator to the atx tranny do i need to plug those or what do i do there or do i use the rad from the 1.8l protege i scrapped. thanks
October 09 2011, 3:38 PM
Post Re: radiator question
If you swapped an ATX to an ATX, then yes you do need to run the cooling lines. The transmission will thank you.
If you did an ATX to MTX swap, then plug the lines coming from your radiator.
If you did a MTX to ATX swap, you're nuts.
92 RS BP05
93 GS KLZE
January 07 2012, 8:33 PM
Profile YIM
Users browsing this forum: No registered users and 4 guests
