View unanswered posts | View active topics It is currently July 06 2020, 12:53 PM
Reply to topic  [ 11 posts ]
 Transaxle Fluid Leak
Post Transaxle Fluid Leak
Ive got a transaxle fluid leak. I changed the gear oil out of it last month and mixed 50/50 with ATF for easier shifting and winter conditions. I notice it leaks now from where the axles (joint shaft?) go into the transmission housing. Anybody had any experience with this? Trans shifts fine, dont wanna swap it out if I can get to a rubber seal or something simple?
94 MX3 1.6 5spd, 09 Eclipse 2.4 auto
December 22 2010, 12:17 PM
Post Re: Transaxle Fluid Leak
Usually means you overfilled it if its leaking from the axle seals
1994 MX-3 RS
Worklog: viewtopic.php?f=46&t=62251
B6 goodies for sale:
viewtopic.php?f=2&t=66333
2nd BP engine: http://www.clubprotege.com/forum/showthread.php?t=46695
December 22 2010, 2:23 PM
Son of a gun. When I filled it, around 2.8 qts, the crazy noise from within stopped. Now that it's leaked out some, the noise has started again!
December 22 2010, 2:41 PM
The difference between ATF and the old gear oil could be letting it leak. I found that when I changed my fluid too.
The axle seals are like $10 each. But you have to pull the axles, which is a b----.
Have you properly checked the fluid level? there is a fill hole on the front of the transmission, it should be up to that level.
December 23 2010, 12:44 AM
Thanks! Yeah I didn't think of the difference between the two fluids, but I guess that could be a huge factor. I haven't checked the level lately, but I'd say at least a half quart has leaked out over a period of a couple weeks. I hate to go back to the gear oil because of cold shift, but think I will try that first before the seals. I've got a new problem now...may not get to drive her for awhile. :cry:
December 25 2010, 9:22 PM
I have a similar issue. I replaced the clutch and filled the transmission with the 75-80 or it was 75-90 oil and it ran nice the first week till i started noticing oild on the ground. a couple days later the shifting got a little harder. Do you think i should replace the seals or do you think its something else? its leaking at the seals.
May 29 2012, 4:47 AM
Also if i replace the seals what do i get? What seal do i need for my 5spd? Is it the CV axel seal or is it a Transaxle manual oil seal-output shaft/input shaft seals?
May 29 2012, 5:09 AM
I don't know what your parts store calls it, but it wouldn't be called an input shaft.
May 29 2012, 7:56 AM
You both need new CV Axle seals. I have nicked one installing an axle and it pissed fluid for a week until I replaced it. They are still available from Mazda or Ford
May 29 2012, 9:58 AM
I would change the seals to be safe. ATX is very thin and I would think that the mixture would cause it to be leaking some. The proper way to check the trans fluid level is off of the Spedo gear in the back of the trans. you should have fluid about half way up the gear when you pull it out, if i remember correctly. If you do not want to run gear oil then go to a full synthetic. I only run 75-90W redline in my gearboxes any more. stuff is great.
May 30 2012, 1:49 PM
When replacing the axle seals, I use a chunk of the old CV. Take the seal and mount it to the CV shaft here:
Make sure the seal "lip" goes into the shaft where it's supposed to. Remove the circlip from the broken CV shaft so it won't lock into the transmission. A touch of grease on the transmission where the seal goes, and of course on the outside of the seal. Line the CV shaft/axle seal up into the transmission as if you were just goin to install it and push until it stops, put a block of wood over the back of the CV shaft and give it a few good taps. This should seat the seal into the transmission without damaging it. Pull the portion of CV shaft out and check your work. If it's not quite in there all the way, try it again. BUT make sure you seat the lip into the shaft otherwise you'll damage it causing leaks.
Also when you're putting the replacement shaft back into the transmission, make sure the lip is seated properly.
PROTIP: When trying to get the circlip all the way into the transmission, a tiny dot of clean axle grease will keep it from falling out of place.
According to rockauto it's called
1992 MAZDA MX-3 1.6L L4 SOHC : Transmission-Manual : Drive Axle Seal
92 RS BP05
93 GS KLZE
June 02 2012, 12:10 PM
Profile YIM
Users browsing this forum: No registered users and 4 guests
