View unanswered posts | View active topics It is currently July 03 2020, 6:26 AM
Reply to topic  [ 8 posts ]
 K8 KLZE Weights Actual Figures!
Location: Backpacking in Canada in vancouver 13march onwards
Post K8 KLZE Weights Actual Figures!
Sorry for the delay everyone, New Years and work got in the way....
Motors have been weighted with oil and exhaust manifolds, But
No water,no flywheel, no Inlet manifold assy, no Auxiliary parts i.e.
A/c pump, P/s pump, tensioner brackets
K8 = 123kgs
KLZE = 126kgs
Alternator = 5kgs
P/S Pump Assy = 3kgs
A/C Pump = 6.5kgs
Tensioner Bracket Assy = 1kgs
Hope this solves a lot of the miss conceptions Matt.. :welder:
January 02 2005, 11:00 PM
Post
wow, only 6 lbs difference, i think this needs to go in the FAQ
January 02 2005, 11:42 PM
Post
yea, the difference in kgs works out to about 6 lbs
January 03 2005, 4:54 PM
Post
Sorry forgot to mention that the inlet mainafold and throttle body
weights in at 15kgs.
Matt :welder:
January 03 2005, 5:45 PM
Post
Do the K8 and ZE intake manifolds weigh the same?
91 Eagle Talon Tsi AWD *RIP*
January 03 2005, 6:28 PM
Post
Thats 15kgs for a K8 one, having removed the KLZE one at the
wreakers yard ( Enuos 800 ) as i did'nt want to pay for it cos they
slug ya for the mainafold, throttle body and injectors.
I can say it would be 15kgs as well plus/minus a kg for a KLZE one.
January 04 2005, 4:33 AM
Post
nice, just as I suspected....virtually no difference.
YOu should weigh the longblocks w/out any accessories brackets or manifolds attached...to see if they weigh the same.
the manifolds definitely weigh more on the KLZE though, they are larger & contain more metal.
DONATE TO MX-3.COM
January 04 2005, 8:55 AM
Post
I would think the only real weight difference between the KL and K8 would be the larger KL crank. Which would be about 3-7lbs.
Mike Evans
Gone:
August 13 2005, 1:31 PM
Users browsing this forum: No registered users and 3 guests
