View unanswered posts | View active topics It is currently May 26 2020, 2:06 AM
Reply to topic  [ 8 posts ]
 Greasing ball joints
Post Greasing ball joints
Ok, I've installed 2 new ball joints.
But left is different from right.
In one of them the grease is coming out through a small hole in the bottom.
I don't understand.
The one with the hole
Other side
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
January 03 2015, 6:42 PM
Post Re: Greasing ball joints
There should be plug that screws in the hole.
January 03 2015, 8:36 PM
How come than that only 1 side has that hole ?
So left has 2 holes (1 with a plug), right has 1 hole (with a plug).
Worklog click
January 04 2015, 6:18 AM
There should've been zerk fitting on there, did you tap/install those zerks yourself or were they already there?
If anything, install another zerk fitting there, that hole is tapped right?
January 04 2015, 12:43 PM
Profile ICQ YIM WWW
It was a manufacturing error. It should have only had the 1 grease fitting on the side
January 04 2015, 1:03 PM
I changed mine 3 weeks ago, new ball joints had either no plugs !
FEBI BILSTEIN : 12904 :wink:
http://mx3france.free.fr/forum/
http://www.mazdafrenchclub.com/phpBB3/index.php
January 06 2015, 4:44 AM
That looks like a tie rod end to me, bit different than a ball joint.
January 16 2015, 1:25 AM
Profile ICQ YIM WWW
You're right ! I 'm wrong !
Because I changed both at the same time ! :roll:
FEBI : 14167
January 16 2015, 10:59 AM
