View unanswered posts | View active topics It is currently February 28 2020, 5:06 PM
Reply to topic  [ 165 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11
 [FS]SuperK's Parts! OEM Full-Length Sides, SE Interior 12/21
Post Re: [FS]SuperK's Parts! K8/KL/B6DE/GS/RS Parts! 6/15/14
I didn't even see the 7-post disty up for sale! I've been hunting for one!
June 26 2014, 9:45 AM
it sort of wasn't... but someone begged me for one and I caved...
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
My GS Worklog Thread
June 26 2014, 9:55 AM
I'm told I am very persistent by my fiancee lol :lol:
Thanks again cant wait till they get here!
June 26 2014, 8:36 PM
Got everything in the mail today, exactly as described, thanks again!
June 27 2014, 11:19 PM
I will try to draw out that template for you later and send it out to ya when things settle down here.
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
June 28 2014, 1:42 AM
Post Re: [FS]SuperK's Parts! A Bunch of GS parts added! 9/5!
Adding:
1x GS Power Steering Rack w/new tie rod ends - $60
1x GS Front Subframe - $50
1x GS Rear disc brake subframe, loaded, includes front proportioning valve - $150
1x Complete GS AC kit - $150
Tons of other stuff, will sort through and list each individually.
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
September 05 2014, 11:16 AM
SuperK's Parts List!
All parts First Come, First Serve.
"Pending" items are items that are not for sale at the moment.
If you are interested in any pending items, please wait until I have them available.
Items are "Buy It Now" Style. I will not "hold" items if I have another buyer ready.
Updated 9/8/14
______________________________________________________________________________
Generic For Sale:
1x passenger power window regulator - $30
1x passenger door shell - $50
1x E-brake cables - $30
1x Hood latch cable - $10
1x Set Hatch Struts - $20
2x Wiper Cowls - $30/each
2x OEM Plastic Oil Caps -$5/each
3x Center Console Center Cubby Holes - $5/each
1x Manual window conversion - $150 (includes door cards, regulators and all)
2x Front mudguards (white or green) - $15/each set
1x JDM Front Lip - $200
1x Interior blower fan/motor - $10
1x 93 GS spindle set, new wheel bearing pressed in, like new ball joints - $100
1x Clutch Master Cylinder - $10 (Any model)
1x Broken Window Switches (Passenger button broken, drivers works) - $5/each
GS Parts:
1x Complete AC system including lines, wiring, relays, compressor and evap assembly (minus condenser) - $150
1x GS Black Carpet, complete - $50
1x GS Heater Coil assembly, mint condition - $80
1x GS Clutch pedal assembly (for manual conversion) incl. master cylinder hard line and stainless steel clutch line. - $30
1x GS Steering Rack - $50
1x GS Rear Subframe w/loaded spindles (Calipers/pads/rotors), front and rear proportioning valve - $150
1x GS Radiator - $60 ($70 w/fans)
1x Front Crossmember and Sway Bar - $80
1x Crossmember Reinforcement (GS Subframe) - $30
1x K8 ECU - $30
1x K8 Intake Manifold w/vris acutators - $20
1x K8 Throttle Body with TPS/IAC/spacer - $30.00
KL Parts:
2x KL/K8 Front Valve Cover w/Breather hole -$10/each
1x KL/K8 Front Valve Cover w/o Breather hole - $10
1x KL/K8 Front Transmission Mount, cracked - $5
1x KLL2 ECU (from a 96+ Xedos9) - $40
1x Harmonic Balancer - $20
1x KL water pump (93 version) - $10
2x Set DE retainers (12) and Keepers (24). OEM New - $150/each
1x Set ZE Pistons, cleaned - $150
5x Connecting rods - $5/each
2x Set DE Springs (12) - 50/each
B6DE Parts:
16x B6 DOHC HLA's, New - $2/each
1x B6DE Clutch Slave Cylinder - $10
1x B6DE Clutch Master Cylinder - $10 (Any model)
1x B6DE New Left Motor Mount (Can include brackets) - $10
1x B6DE Fuel Rail w/FPR - $10
1x B6DE Brake Booster - $10
1x B6DE Power Steering Pump - $15.00
1x B6DE Radiator, No Leaks - $60
1x Tested AC Compressor, R134A, B6 (Rebuilt eBay Special!)- $40
1x B6DE Front Transmission mount for 95 rs (slightly cracked) - $5
Pending
1x Driver side fender (white) - $30
1x Driver side door shell - $40
1x Sunroof Assembly - $60
Local Pickup:
Passenger side door shell - $40
GS Hatch w/wiper - $50
OEM front hood, frame slightly separated - $20
Rear subframe (for RS to GS disk brake conversion) - $100
Sold:
1x '93 Front dash, mint - $100
2x B6DE MAF - $10/each
1x Set Chrome Interior Handles - $25
1x GS Front Lip Set - Cracked - $30
1x UK Window switch excellent condition - $60
1x OEM MX-3 shifter - $5
1x OEM MSP5 shifter - $50
1x Set AZ3 Stainless sides - $200
1x Set Eunos Stainless sides - $200
1x Starter - $20
1x Set ZE heads, bare. Great condition. - $80
1x OEM USDM Bumper (Teal) - $20
1x Green damaged Mazdaseed replica front bumper $150 SOLD
1x Set K8 Injectors, in fuel rails, tested - $20.00
4x B6DE Injectors, professionally rebuilt/cleaned/flow tested 1 year ago - $10.00/ea
3x Euro Window Switch - $50
2x Set of clear USDM Headlights - $30
1x Chilton's 94-98 MX3 Repair Book - $10/Each
1x Wytbishop's Endlinks - $150
1x Genie B6 Headers - $75
1x B6DE Water Pump, 1 Year Old - $15.00
1x Set USDM clear plastic headlights - $20
1x Sets KL Injectors, tested - $30
1x Rear Crossbar (Bolts to the bottom seatbelt bolts) - $50
1x Set of B6 Miata Stage 2 Cams - $250
1x Set of JDM Headlights - $100
6x EDM Bumper Cover - $150
5x Set Rear Mudguards - $40
1x B6-DE MTX Transmission - $75
1x Slim Visors by FowlJesse - $100
1x Set JDM Full Length Sides - $400
1x JDM Front Lip -$200 - Curtklze
1x Set of front SE Leathers -$200
1x Set of Euro Signals - $30
4x Front Lip, Complete - $50
1x Flowmaster 60 Series Muffler, includes Chrome insulated single tip - $50
5x Euro Mini Side Skirts - $150
2x Black Front Lips, Complete (needing epoxy, cracked on the passenger side. 2 pairs) - $25/each
4x Chrome Interior Handle Set, Great Condition - $50
3x OEM Euro Foglight Set - $30
2x OBD1 '93 K8 ECU's, Chippable - $30.00
3x Front Tow Hook - $20
1x B6 DOHC Distributor - $50
2x Fenders - $60
1x K8 AC Compressor - $30
1x Vacuum Solenoid FPR/VRIS
1x Stock shift boot
1x Carbon fiber gauge sticker
1x 3rd Brake Light
1x KL/K8 rear valve cover
1x KL47 Intake Manifold
1x Roof rain rails - $15
1x Drivers side power window regulator - $60
1x Broken drivers side window switch - $5
1x B6DE MAF (B6BF)
1x sunroof metal deflector and links - $30
2x GS Spoilers (Black/Teal) - $20/each
1x Euro center vents - $20
Payment:
[size=50]
Preferred: Check/Money Order. PM For Address
Not Preferred: Paypal. Superk86@gmail.com. Add appropriate % for fees.
Updated parts list. The following parts are no longer available:
Currently Parting Out a GS. May have other parts not listed available. feel free to ask.
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
September 08 2014, 7:40 PM
Adding:
1x Euro mini sides, red - $75
1x Euro dash vents (closable, 3 pieces) - $50
1x 92-93 Window Switch, no "auto" function - $70
1x Glass LHD headlights. w/motor, missing 1 tab. Glass has been removed and interior painted black. $200
1x Foglight set with brackets - $50
1x Set of Front SE leather seats - $300
1x Set of Rear SE leather Seats (upper/lower bench) - $300
Updated 11/10/14
Generic For Sale:
2x Center Console Center Cubby Holes - $5/each
1x Broken Window Switch (Passenger button broken, drivers works) - $5
GS Parts:
KL Parts:
2x Harmonic Balancer - $20
2x Set DE retainers (12) and Keepers (24). OEM New - $150/set
B6DE Parts:
Pending
Local Pickup:
Sold:
1x Driver side fender (red) - $30
1x Center Console Center Cubby Holes - $5/each
1x Starter - $20
2x Fenders - $60
1x Stock shift boot
1x 3rd Brake Light
1x B6DE MAF (B6BF)
Payment:
[size=50]
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
November 10 2014, 2:10 PM
Post Re: [FS]SuperK's Parts! Euro Parts and Leather SE Seats! 11/
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
November 10 2014, 3:04 PM
May accept monthly payments. Ask with details of payment arrangements that can work for you
Updated 12/21/14
Generic For Sale:
1x Set Full-Length OEM sides, red - $800
1x Erebuni rear bumper, new, primer - $250
GS Parts:
KL Parts:
B6DE Parts:
Pending
Local Pickup:
Sold:
1x Starter - $20
2x Fenders - $60
1x Stock shift boot
1x 3rd Brake Light
1x B6DE MAF (B6BF)
Payment:
[size=50]
Adding:
Sold:
1x Glass LHD headlights. w/motor, missing 1 tab. Glass has been removed and interior painted black. - $200
1x Glass LHD headlights, casing damaged, good lenses. - $100
1x OEM MX-3 floor mat set - $50
1x window switch, no buttons just PCB - $5
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
December 22 2014, 12:45 AM
Erebuni rear bumper pictured in middle: (other front bumpers are not available)
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
December 22 2014, 12:50 AM
Post Re: [FS]SuperK's Parts! OEM Full-Length Sides, SE Interior 1
PM about JDM front lip & USDM lip.
1996 MX-3 KL-ZE with Eunos 800 IM, factory side skirts,. "Owner since 2001 my 14th year"
1992 929s 20B-REW Lowered, 17" chrome Millenia rims, custom black interior. "13th Owner 9th year"
2006 Chevy HHR LT "Bought Brand New - East Side Chevy" Sold to my Dad
March 01 2015, 2:29 PM
Didn't realize we have a second dizzel here... lol
Sweet collection of parts that you have accumulated over the years! You have a set of Blaze red OEM sides, nice! i wanted the JDM ones for years and would have traded mine gladly for pair.
March 01 2015, 2:33 PM
Really? I didnt like the JDM sides as much as the US version. I had both and sold them.
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
March 01 2015, 7:43 PM
:shock:
March 01 2015, 7:52 PM
Users browsing this forum: No registered users and 4 guests
