View unanswered posts | View active topics It is currently January 20 2020, 10:27 PM
Reply to topic  [ 45 posts ]  Go to page Previous  1, 2, 3  Next
 How to: Sound-deaden \ Rattle-proof your ride - Affordable
Post Re: How to: Sound-deaden your whole car for under $100
i did the same thing in my mazda6. but took it a step further.
i laid down 200 SQ FT of fatmat sound deadener. then took expanding foam in a can, and filled all the voids in the chassis rails, the rear trunk areas. and then filled my A, B and C pillar with it also. (if you knock on a pillar, it sounds solid now). then i took poly fill and foam matt and used it to fill in any dead area behind any panels. i also used the expanding foam to fill in all my empty areas in the hatch itself.
October 23 2010, 10:15 AM
Dope! Two questions..
1. Why did u do this in a mazda 6
2. How my did the foam fill help
October 23 2010, 12:31 PM
3200 watts RMS is why. lol. i have two 15 inch Ground Zero nuke's powered off two mtx 1501D's.
the explanding foam made a major improvement. ive actually done that even to my winter beater now. the biggest difference is the hatch part. that thing was so crappy and thin. once i foamed it, now its just solid. the entire car sounds totally different now. i still plan on doing more to it in the future. but havent figured out my next step to do. the expanding foam is a big trick with the drift people also. it tightens up the suspension quite a bit instead of having all hollow frame rails and such
October 23 2010, 1:03 PM
Link to product?
October 23 2010, 2:02 PM
I was just reading on another forum, apparently one of the downsides on these types of material, is that in hot weather, the tar will run. You installed it in October, so we'll maybe see next year, but maybe that's something that will more likely happen in the hotter weather down south.
December 11 2010, 9:42 AM
Profile ICQ WWW
I can imagine that it might get a little peel-ey. Its pretty much an aluminum backed shingle (roll roofing). Which won't stick permanently to a vertical surface. May require additional fasteners for hot hot weather... we all know cars become ovens.
December 11 2010, 11:07 AM
I'm waiting until warm weather testing has been conducted for this myself. If all goes well, I'll do it immediately! My main concern is maintenance, I don't want it in the wrong places.
'12 Challenger R/T Plus w/ STP - 3.92 w/ Limited Slip, Shorty headers, SkipShift delete, Clutch Delay Valve delete, Hurst STS, RAM Clutch Adjuster, StopTech 6 Piston Brakes, Sticky Nittos, Tuned
'92 GS 5 spd - Straightneck KL, 67mm TB, MegaSquirt, Coilpacks, 5 lugs, Speed6 brakes, FD wheels, wiretuck, progressive coilovers, shorty headers w/ custom collector, AEM WB, 2.5" straight, Borla XS
December 22 2010, 2:54 AM
in my opinion the tar may run in the extreme temps but if you think about it you have it behind panels and under carpet so i wouldnt think it should run to much if at all funny thing is my fiance works at lowes so this means dicounted price plus she can also further research this product as to how well it holds up to heat and anything else that could effect it
92 MX-3 6cyl dohc 24 valve K8 cold air filter custom exhaust drift body kit carbon fiber hood 17" focal rims Kenwood KDC-MP635 headunit Pioneer 6.5" componet door speakers and 4" rear speakers 500 watt boss amp powering 12" sony explod
My Work Loghttp://www.mx-3.com/phpBB3/viewtopic.php?f=46&t=76603
December 22 2010, 5:47 PM
Theres is proof and vids on youtube that this product holds up in heat, just like dynamat would.
December 22 2010, 6:04 PM
thats what i figured its pretty much the same thing just dont have the name so it dont cost a fortune
December 22 2010, 6:11 PM
Couldn't find Peel & Seal at Home Depot or Rona...
$i$Ko
Ride:
1992 Midnight Purple MX-3
Worklog:
viewtopic.php?f=46&t=75646
viewtopic.php?f=37&t=76781
April 01 2011, 5:27 PM
Lowes thing. Can't get it in Canada.
April 01 2011, 5:30 PM
Imagine if οne day something happens and you must take off all of this thing from your car.. :shock:
Black Mazda Mx3 Rs 1997 B6DE
April 01 2011, 7:21 PM
Yea you can.., calgary gained a lowes now
Worklog for the Blue One
Worklog for the KLZE
First Car, And My baby... $550 To buy and repair from Write-off... The radio and amp that was in it was worth more than that!!!.
Hunting For a Supra MKIV, but I'll never get one. Still Hunting.
April 01 2011, 8:09 PM
So they got a lowes after I said that? You sure proved me wrong.
Anyways, yea, I see that Lowes are starting to come to Canada. Wonder if they carry this product now.
April 01 2011, 8:32 PM
