View unanswered posts | View active topics It is currently July 07 2020, 2:17 AM
Reply to topic  [ 3 posts ]
 Which engine oil? Tyre pressure?
Post Which engine oil? Tyre pressure?
Hi, everyone!
What kind of engine oil should I put in my MX-3 with 1.8 V6? 5w40, 10w40 or 10w30?
MX-3 has 180'000 km on clock, and is living in Europe with temperatures as follows, from -30C (once or twice during winter period) to +35C (during the hottest summers), but usually it's from -15C to +25C.
Also, what tyre pressure needs to be in 205/50 R16 tyres?
March 30 2015, 8:06 AM
Post Re: Which engine oil? Tyre pressure?
For the tires I'd say what's listed on the door jamb as factory. Adjust up or down at most 2PSi depending on how rough/easy you want the ride to be, or what you'll be doing with the vehicle; track, drag, etc.
Use recommended weight oil in the engine by manufacturer. Usually 5W-30. If your engine ticks, fix it. If it leaks, fix it. If it burns oil, fix it. No sense in masking the problem by going with a heavier weight oil; you'll do more damage in the long run.
91 Dakota 239; header back, SRI, emissions delete.
92 MX-5; H&R, Prothane Total Kit soon
Wife's:
12 Hyundai Elantra 6 Speed Manual
92 MX-3 GS; KL-ZE swap, Maxxim 17's, Pacesetter catback, SRI. FOR SALE
April 20 2015, 9:53 PM
:lol: I reckon most the K series V6 ticked right off the production line. Good luck with that :freak:
I've been running 5W-30 forever since my rebuild. 0/5/10W-30 will all work similar. They're all 30 weight in essence (when warm). Since your coldest temps are rather cold, I'd go 5w30 or even 0w30.
205/50/16 - I'd go anywhere between 32-36. Whatever feels best.
1995 Eunos 30x KLZE
April 28 2015, 8:50 AM
Users browsing this forum: No registered users and 6 guests
