View unanswered posts | View active topics It is currently January 22 2020, 10:01 PM
Reply to topic  [ 8 posts ]
 Can I Fix This¿?¿?
Post Can I Fix This¿?¿?
Imageo this is my broken fpr solenoid. Its paired with another thing like it on top of intake. Vaccum line from fpr to this to the one next to it then else where...I throw the code for it ones I hit highway. I now have an emergency 4hr trip to make and because of this im burning gas quick. So is there anyway to fix this like tap wires into the one next to it bypass it vaccum wise. There was none at the yard and money I have goes to gas and the emergency. Any help asap os greatly appreciated as I pull put tonight no later then midnight.
May 20 2014, 4:11 PM
Post Re: Can I Fix This¿?¿?
http://mx-3.com/manuals/showimg.php?fil ... F2-007.gif
its one of the vacuum solenoids for your egr, your car will run fine without it but yes you will loose about 3-5mpg. In the meantime drive passively and you should be able to make up a good part of the difference in your driving style until you can locate a spare.
Try messaging Caleb on here, he has 2 spare v6 cars that should have one
May 20 2014, 10:08 PM
Yup that sux I was hopin itd be something I can fix before I leave in a few hrs...moderate driving is kinda not an option since ima be goin thru the mts..but ill figure it out when I get bak.
May 21 2014, 12:11 AM
Removing EGR reduces MPG??
If you removed all of it and capped off the vacuum hoses it should still run fine.
1995 Eunos 30x KLZE
May 26 2014, 7:02 AM
Yes it will still run fine as mine does, but yes you will hurt your total MPG running without one:
http://auto.howstuffworks.com/fuel-effi ... ation2.htm
May 26 2014, 10:39 AM
Just make sure the EGR is closed and you'll be fine. If you need to pass an E test chances are without the egr working you'll probably fail as the ERG allows for a more complete HC burn.
May 26 2014, 5:35 PM
Yea u have a Classic Rod Registrantion no smog required.
May 27 2014, 2:14 PM
::UPDATE:: So I found one but it was broken too...mine were bolted directly on top of the manifold so I assumed all the others at the yard were gone...but I didnt know it was located out of site behind the TB so all check engine codes shpuld be alleviated by tomorrow but hell I cant comeplain I got the car for 250 bux couple months ago and have put 12K+ miles on it since...
May 30 2014, 12:21 AM
