View unanswered posts | View active topics It is currently August 04 2020, 4:15 PM
Reply to topic  [ 8 posts ]
 Need help with VAF testing
Post Need help with VAF testing
So I tested my Vaf meter today according to manual spec and readings are as follows.
E2-VS - closed 295 ohms and open is 167 ohms also reading jumps up and down (examp. 295-411-344-256-522-264-364-167) is this normal?
E2-Vc - closed 280 ohms and doesn't change from closed to open
E2-THA- closed- 2270 ohms and also doesn't change from closed to open
According to these readings would you say I have a bad VAF?
Work Log: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=80716
May 10 2014, 10:47 AM
Post Re: Need help with VAF testing
If your using an digital meter then ya your readings will be all over the place at times. I'd start by cleaning the resistance wire, you have to be delicate so don't blast the throttle body/maf cleaner at it.
May 11 2014, 5:58 PM
Is it normal for readings not to move on two of the tests when opening? Thanks for the reply.
May 11 2014, 8:21 PM
How do I clean resistance wire and why would my readings be all over the place if using a digital multimeter? Thanks
May 12 2014, 7:01 AM
Just check out Youtube, there's videos there showing how to clean the resistance wire(s) in your vaf. Digital gauges bounce around a lot where as analog gauges tend to give a more stable reading.
May 12 2014, 7:44 PM
I understand digital meters bounce around, but when I hold it in one position and is showing an incorrect reading then I feel its probably accurate. I've tested them before just been awhile but don't remember second guessing my results. I also didn't find any videos on cleaning VAF's just MAF's.
May 12 2014, 10:02 PM
Figured it out on my own as I usually do. :lol: Thanks Dan for trying. :)
Funny how when I notice just the littlest decrease in performance, I instantly start diagnosing and testing everything and sure enough even though I had no codes there was still a problem. Damn I love a properly running N/A ZE!
May 15 2014, 11:17 AM
i would like to know how to clean it too. it might help mine run better.. any links?
March 03 2015, 6:00 PM
