View unanswered posts | View active topics It is currently July 11 2020, 3:55 PM
Reply to topic  [ 5 posts ]
 Connector under dash
Post Connector under dash
Hey guys it's been a while, I need some help. Under the dash on the drivers side behind the fuse box there is a 6 pin white connector that I cant seem to find where/if it plugs in to anything. its connected to the wiring harness that runs into the relays behind the fuse box. The colour on the connectors are. it's a 94 mx3
Red
Green/Pink
Green/Red
Green/Orange
White/Green
Black/Pink
it's not long enough to hook into the fuse box if it could, nor is it long enough to go up to the dash. I honestly cannot remember if I even unhooked it.. It's down by the clutch left side.
Own
1994 MX-3 GS swapped ZE
1994 MX-3 GS Swapped ZE (Gone)
1996 Dodge Dakota Sport v8 Magnum
2007 Ford Fusion SE
WORK LOG: viewtopic.php?f=46&t=81232
My MX-3 is nothing without me, and i am nothing without my MX-3
May 08 2014, 5:48 PM
Profile YIM WWW
Post Re: Connector under dash
Hey there, I might be able to help. I have a 94 gs 1.8L and I just swapped out all relays and fuse block so I'll take a look today, I also have a few wiring schematics of the fuse block and also which plug is which that goes to it. I'm still trying to figure out the picture posting but I should have em up in a day or two.
May 09 2014, 9:12 AM
hey thanks for the help. You can send the pictures to my email it'll be faster moneyshot23@kos.net
Own
2007 Ford Fusion SE
May 09 2014, 4:08 PM
Profile YIM WWW
Sent you an email with schematics and a pick of my relay's under the dash, hope that helps.
May 10 2014, 2:43 PM
Thanks for the help.
Own
2007 Ford Fusion SE
May 11 2014, 12:20 AM
Profile YIM WWW
