View unanswered posts | View active topics It is currently July 15 2020, 7:39 PM
Reply to topic  [ 13 posts ]
 Radiator hoses
Post Radiator hoses
Is their any replacement hosese for the v6
Or are all the performane hoses universal
March 22 2014, 9:55 PM
Profile YIM
Post Re: Radiator hoses
I am about to get measurements of all the cooling system hoses and make a list of Samco hoses for replacement =] Not making any promises for how soon I will do this (super busy with career) but, it should happen sometime next month. Here's the link to the universal straight hoses I will be sourcing from http://www.samcosport.com/usa/rp_straight_hoses.asp
93 MX3 SE (klze conversion in progress)
03 Elantra GLS (DD)
92 MX3 GS sold :( missed!
The very air around me seemed to catch fire and freeze at the same time, that's how I knew he had enough for today.
Rangers Lead The Way!
March 22 2014, 10:25 PM
cool idea wouldnt mind hoses that last a tad bit longer on a stock application :2thumbsup: :2thumbsup:
March 22 2014, 11:01 PM
Profile YIM
I just ordered the all aluminum radiator from silla an should be here in a week so its be best to do it some time soon
March 23 2014, 5:02 PM
Profile YIM
last time I got mine they had to get the lower through the dealer, the upper is a straight hose just about so Im sure you could get a samco from another application that would fit.
March 23 2014, 5:03 PM
Theirs a klez set up for a probe would that work :shrug:
March 23 2014, 6:26 PM
Profile YIM
I'm currently on my way to DC and won't be back till Thursday. I should be able to get measurements then. Unless someone else can give me a list of the stock hoses with inner diameter and wall thickness measurements and I can compile a list from my phone.
03 Elantra GLS (DD)
March 23 2014, 7:23 PM
The hoses in blue are the ones I took measurements of. Wasn't exactly the easiest thing to get numbers for, but not the hardest either. I am going to do all of the hoses under the IM when I pull the engine out. I wrote the measurements for each hose in case you want to find a different vendor to source other hoses (cheaper ones hopefully. Samco is expensive!) But for simplicity, I put the straight and XtraFlex part numbers from Samco. If I forgot anything let me know!
Happy Tuning! -icajewler
03 Elantra GLS (DD)
March 28 2014, 10:17 PM
Price isn't a factor what ever I want I get :D
March 28 2014, 10:59 PM
Profile YIM
Hi ICA......These hoses must already exist in the SAMCO catalogue.
I have the SAMCO hoses in blue, in the fitments as numbered #4 and #5 in your post image fitted to my Eunos Presso (MX-3).
They were fitted to a JDM Mazda Lantis (2.0LV6) which I picked up second hand.
Chris
Eunos Presso HI-XS Special Edition, KLZE, KL47 IM+TB, MX6 LSD box OEM front s/bar, Outlaw IM+TB thermalbloks, lightened K801 fly, XTD Stage 3 clutch & cover balanced to f/wheel, mbolin tranny saver , walbro 255,short shifter, SRD shifter bushings- H&R Springs and Koni inserts, MSpeed engine mounts, SS brake and clutch lines, PRM CAI,Whiteline rear strut and swaybar, 7x17 Konig/Maxxim Fourteen rims, and stuff.
March 29 2014, 1:46 AM
Chris
I will try to find them! :) Thanks for the input!
03 Elantra GLS (DD)
March 29 2014, 6:51 AM
I found out by emailing them that kit number tcs395c contains three hoses and the two big ones are a direct fit. I think its numbers 4 & 5. Maybe 3 & 4. Anyway, its for a 2008 gtr. Here's the link http://www.samcosport.com/usa/car_kits.asp?make=Nissan its like 16th down the list or so.
03 Elantra GLS (DD)
March 29 2014, 9:03 AM
Theirs three hoses in the kit 2 of them for sure are from the block to the radiator can the other one be split for the side tank hanging off the radiator
March 29 2014, 6:46 PM
Profile YIM
