View unanswered posts | View active topics It is currently July 06 2020, 7:56 AM
Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
 quick and easy compression testing
Post
So what is true "good" compression? Anyone find out? Do they have that compression tool at AutoZone also? I'll have to check.
March 11 2006, 11:26 PM
Post
the klze should be 210psi, the k8 should be 195psi, and the b6 should be 185psi. the limits of tolerance are +/- 10% for each cylinder and you have to make sure that there is not more than 30psi difference between any 2 cylinders.
kevin (aka The Oven)
93 mx-3 GS KL-ZE with KL31 cams and properly chipped ecu
All mods are on my website: http://ca.geocities.com/ovendenk
MX-3.com Worklog: http://www.mx-3.com/phpbb2/viewtopic.php?t=48462
March 12 2006, 10:33 AM
Post Re: quick and easy compression testing
really? i got 180 all across the board :/ i had 190 like 1 year ago.
162 whp at the dyno.. hmm
its just a worn out ze i guess.
-hec
May 19 2008, 2:58 AM
Post Re:
That does that do if it is?
July 28 2008, 10:48 PM
Profile ICQ WWW
ovendenk wrote:
should i be concerned with the 20psi difference between #2 and #1?
probably just build up on the valves not letting them seal correctly....
November 22 2008, 6:29 PM
As far as I know a compreesion test s/b done with a warm engine, plugs out, to get optimum results. You might find that your psi difference between cylinders is less with a warm engine. sounds like good numbers to me anyways. Since you havent started your engine up, you may have a little more or less oil in some of your cylinders. :)
April 14 2009, 5:48 PM
