View unanswered posts | View active topics It is currently June 03 2020, 11:20 AM
Reply to topic  [ 21 posts ]  Go to page 1, 2  Next
 quick and easy compression testing
Post quick and easy compression testing
alright today i was determined to get my compression results from my new motor. i eventually tracked down a compression tester for $13 at princess auto (princessauto.com) and i also got a squeeze type starter switch for $3. the advantage to using the switch is that you don't need to disconnect anything electrical. DON'T EVEN PUT YOUR KEY IN THE IGNITION.
all you do is disconnect the wire from the solenoid that's clipped on and connect the two switch clips to where the red circles are in the pic. then one by one you unscrew the spark plug and screw in the compression tester only hand tight and hold the starter switch until you've reached maximum pressure on the tester. it should only take about 5 seconds per cylinder. write down the results and release the pressure, then unscrew the tester and put the spark plug back in and move on to the next cylinder.
15 min and i was done my very first compression test. i got 205, 215, 205, 210, 215, and 210 for my #1 through #6 respectively.
kevin (aka The Oven)
93 mx-3 GS KL-ZE with KL31 cams and properly chipped ecu
All mods are on my website: http://ca.geocities.com/ovendenk
MX-3.com Worklog: http://www.mx-3.com/phpbb2/viewtopic.php?t=48462
November 17 2005, 12:28 AM
BANNED Member
Post
Good description and pic! Great idea the squeeze switch.
AND good results on the test! :2thumbsup:
November 17 2005, 12:33 AM
Post
Nice job Kevin!!
FWIW, I believe it's best for that process to have all of the spark plugs out ahead of time. And then go from cylinder to cylinder to do the test. The remote starter looks to be a pretty handy tool.
November 17 2005, 6:30 AM
Profile YIM
Post
thanks guys. btw, you can use and any switch you can find. and the reason i like using the switch is because you can use it under the hood and watch the pressure gauge as you turn over the engine and make sure everything is ok.
November 17 2005, 9:30 AM
Post
Kevin, those are some pretty high compression numbers. These are from the (yet to be installed) ZE? I thought max compression available for the ZE was 210lbs??? If that's the case than perhaps leaving the other remaining spark plugs in while doing each cylinder may taint the teast readings. Anyone else confirm this?
November 17 2005, 2:20 PM
Profile YIM
Post
does it matter that i loosened them all? i wanted to do it quickly, so i unscrewed each of them about 2 rotations to be able to take them out by hand. then, i hand tightened them.
i'll redo the test and let you know what the numbers are without plugs.
btw, i did each cylinder twice for accuracy. and this was on a cold engine since i have no tb, alt, rad, or disty to run the engine with.
November 17 2005, 2:38 PM
Post
Something else I just remembered, was that the TB is supposed to be held open when cranking the engine over for each test.
November 18 2005, 9:51 PM
Profile YIM
Post
ran out of time to do the retest with no plugs, but i don't think the intake could get anymore open since i have no tb or intake system on the ze car right now. :shock: :P
tomorrow night, i'll redo the test.
November 19 2005, 1:46 PM
Post
alright, pulled the plugs and redid the test. i got 202, 220, 205, 210, 216, 212 with no plugs and 205, 215, 205, 210, 215, and 210 with slightly loosened plugs for the #1 through #6 plugs respectively. basically the same.
should i be concerned with the 20psi difference between #2 and #1?
November 20 2005, 11:13 PM
Post
"Oven", those are still pretty high numbers for a ZE and I was hoping by now someone could step up and confirm what the "majic" number or max compression reading should be. You're still within the 10% range Kevin.
December 16 2005, 2:46 PM
Profile YIM
Post
it's probably because he has no intake manifold... is it even possible to have compression that is too good? :lol:
CARDOMAIN WITH UPDATED PICS
January 10 2006, 5:12 PM
Post
:confused2: when did i say i had no IM? when the test was performed both times the intake manifold was securely attached. the only thing i did wrong on the first test was not removing the spark plugs. i just removed the plug in one cylinder, did the test, then put it back and moved on to the next cylinder. the second test was performed with no spark plugs.
January 10 2006, 5:54 PM
Post
well when you said:
considering that the intake manifold is part of the intake system...
February 08 2006, 7:52 PM
Post
i beleive the compression for a ze is 220 psi irc
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
February 08 2006, 8:13 PM
Profile YIM
Post
true enough although it was a mix up. i have the intake manifold, but no tb or intake tubing. sorry for the confusion.
February 09 2006, 12:20 AM
